Configures the maximum amount of memory that is allocated to the identity management database.
| Kbytes | Specifies the maximum amount of memory to be used for maintaining identity information. The range is 64 to 49152 KB. |
512 KB.
If the current memory usage is higher than the memory size specified in the configure identity-management database memory-size command, the command is not successful and a warning message appears. The message indicates that the current memory usage level is higher than the configured level and that the memory can be freed only when existing identities log out or disconnect.
The following command allocates 4096 kilobytes to the identity management database:
* Switch.4 # configure identity-management database memory-size 4096
This command was first available in ExtremeXOS 12.4.
